mine cant display bt it does start
Mine can start bt does not display, the screen is blank
You need to make sure about your cable connection or replace your Monitor for a while. if it still not working then it might be problem with Graphics, Ram and motherboard.
So you need to check your graphics card and clean your ram and processor fan then install it back in properly. once you will do that then you need to try to start your computer. it will start working fine.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 196
