メインコンテンツにスキップ
Released by Sanyo in 2004, this flip phone is 3.34 by 1.85 by 1.02 inches and weighs 3.6 ounces. The device's features include an internal and external LCD screen, camera lens with flash, and speaker.
Why is my device not turning on?
I keep pressing the power button to turn my phone on and nothing is happening. What do I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
One of these should help.
1. Drained Battery
If your phone will not turn on, the battery may be low in charge. Plug your phone into the charger, wait 5 minutes, and try turning the phone on. If that does not work, wait until the phone is fully charged, then try again.
2. Bad Battery
If your phone will not turn on after you charge the battery, the battery may be dead and unable to hold a charge. In this case, you will need to replace the battery.
3. Battery Connection
Make sure the battery is connected correctly. Open the back case, remove the battery, and put it back in. Try turning the phone on again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jamie Peiffer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 355
