メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Phone won't charge through port. Is wireless charging an option?
I have a damaged logic board and my phone won't charge using the sync/charging cable. I know it's most likely due to damage to one or both of the chips that control USB charging. It's not recognized bu iTunes either. I just get a USB device not recognized error when I plug it into my PC which further confirms my suspicions. The phone does charge if it's plugged in while off though, so i'm guessing the charging coil is still ok.
Anyway, since I can't use a cable, would I be able to charge my phone wirelessly somehow as long as the coil is still good? I've seen special cases you can buy that do that kind of thing. Would they work, or do they rely on the USB charging circuit in some way as well?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The iPhone does not offer wireless charging (from the start thru to the current iPhone 6).
There was a device you could plug in via the port connecter to make your phone charge wirelessly but as you have a damaged port that won't work either.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Update: The iPhone 8, 8 Plus, X, XS, XS Max & XR all offer Qi wireless charging.
さんによる
コメントを追加
回答を追加する
Jesse さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 1,777
