What is that hole at the top of tablet?
Hole is approximately 1mm. Located on the top deep side.
I think he means the ~1mms diameter hole ~7mms centerward from the headphone jack. Without investigating further, I'm guessing it's the microphone.
このアンサーは役に立ちましたか?
When I took off the case, I found something. I have no idea what it is. If you hold your fire tablet to where the volume and off button is facing your right, and then face the tablet upwards, then look at the right of the thin part, you'll see something that looks like it can be opened. I opened it and I still have no clue wth it is
このアンサーは役に立ちましたか?
It's for an SD memory card..... smh
MicroSD card
Which model of Kindle Fire HD is it? My guess is the microphone but it’s hard to tell without knowing the exact model. There is a list of models with labeled images of each here: https://www.lovemyfire.com/kindle-fire-t...
I hope you find the answer and post it back here.
このアンサーは役に立ちましたか?
It's the microphone. You can get the manual here, as of 9/19/24
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 6
過去 30 日: 30
今までの合計 6,300
1件のコメント
Hi Billy, can you be a little more descriptive? Perhaps a picture? Or if the hole is visible in a teardown image, a link to that?
Andrew Optimus Goldheart さんによる
