メインコンテンツにスキップ
Lexmarkプリンターの修理ならびに解体ガイド
Lexmark Genesis s816 has slowed to a crawl
After several years of very successful use, my multifunctional device slowed to a snails pace when printing anything. It takes over 4 minutes, for example, to print a test page. What could be the problem?
The device is running the latest firmware.
Thanks, Anna
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
HOW TO FIX LEXMARK GENESIS SLOW PRINT
I have also had a lot of problems with slow printing of and on. Never had time to look into the problem until now.
- First try closing network/wifi connection via the display on the printer.
- Power off the printer.
- Close any wifi or other network connections you have been using for the printer. Like a router, mobile device etc.
- Use the USB cable ONLY for printer connection.
Now power the printer on again.
- Make sure the wifi-icon on the display HAS the yellow triangle warning. If not start over again from top.
- Test printing again.
If the problem persists update drivers etc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
belkjab さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 261
