メインコンテンツにスキップ
PowerPC G5プロセッサを搭載したiMac G5は、2004年にリリースされました。
453回答 すべてを表示
iMac G5 with intermittent power on
Hi,
I have an iMac that starts up fine most of the time.
It can go for days working just fine.
When it fails, a push to the power button does NOTHING.
Inevitably, if I try enough times it works fine!
Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Probably a failing power supply. To get you to the correct part we would need to know your exact machine. The power supply probably has to cool down before a restart. Open it up and look at where the power leads enter the power supply form the motherboard. If you see a burned area close by, you will know for sure. Opening up this one is usually a matter of three screws on the bottom of the frame. The part looks like this: [リンクされた製品が存在しない、もしくは無効: IF165-002]
Here's how to get to the typical G5 iMac power supply:iMac G5 17" Model A1058 Power Supply Replacement
Again, check your model, it's located on the bottom of the stand.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The iMac is a first generation 17" iMac and has no burned leads. It has a apple 661-3351 power supply.
You suspect the power supply, but when I run through apple's iMac test procedure,
http://support.apple.com/kb/ht2173
none of the buttons get the cool iMac to start up - when it's in failure mode (like today).
Do you still think it's the power supply?
さんによる
コメントを追加
回答を追加する
bsmith1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,078
