メインコンテンツにスキップ
An Android prepaid smartphone released in 2013 by Virgin Mobile. Model number: N800.
Why does my ZTE Awe Has Shortened Standby Time?
My Phone's battery life drains so quickly, even when I'm not using it. My phone will be apparently inactive for hours, but when I check the battery life, the percentage shows a decrease in battery life.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
Be aware of excessive applications running in the background as well as screen brightness. If these simple fixes don't improve the battery life, the battery could be damaged which in case you would contact the manufacturer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My phone has the same issue, apparently this model is battery hungry. I manage it by leaving the Bluetooth and wifi turned off, unless it's on a charge cable, or I use the functions for a minimum period.
Try eliminating all but those apps that you use often, also have a large capacity mini SD card inserted, move all apps that you use to it, and perhaps get a backup battery booster.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joseph さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 155
