メインコンテンツにスキップ
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Solution for distorted audio?
I've never had a problem with my phone's audio until recently where it's become distorted and quiet, what could have caused this problem and is there anything I can do to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
There are a few things that can cause your audio to stop working properly, and each requires a different fix. The first thing you should do is make sure that the holes over the speakers aren't just clogged. Look on the back of your phone, and see if there's dirt in the small line of holes near the bottom. If there is, running a fine needle through them should solve the problem. If that doesn't help, try making sure your software is up to date, because this might also be causing performance issues. If there still isn't any improvement, your speakers have probably blown out. You'll have to replace them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nyles Peterson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 129
