メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
No SIM. Keep getting the No Sim messsage
I have tried many fixes, from switching from airplane mode to normal mode, putting tape on the back of the sim card, getting a new sim card, changing carrier, reinstalling OS, talking nicely, shouting abuse, but nothing makes it work. Is there a part I can replace? is it the sim contacts inside the ipad, is it the logic board, is it just me? Any help any one thank you.
Sam
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
A few questions.
Did you just get the iPad?
Have you always had the No SIM error, or is it a new occurrence?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've had it a couple of years, it was second hand when I got it, the sim was working fine. 6 months ago the fault started on an intermittent basis, getting worse more recently which makes me think it is a hardware problem rather than soft or firmware issue. Many thanks for any help you can offer. Sam
さんによる
コメントを追加
same problem here :-(
it happened after iOS7 update.
is a well known problem on apples forums, maybe its supposed to stop working so you should buy a newer iPad...
any news on this ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I once sold a used iPhone 4 and the new owner got a strange "No SIM" message when going thru setup. This was very strange indeed, since it was a Verizon device and had NO Sim slot! Anyway, the new owner got it fixed by calling Apple Support and being referred to an engineer who killed the "bug". The process took a few days.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 207
