メインコンテンツにスキップ
J.D. Corporation's JD Razor kick scooter was released in 2000 and became the most popular kick scooter brand in Japan. The JD Razor 2000 is a special-edition kick scooter that features an added wheelie bar and linear spring suspension. Often a strap and light are included with the scooter.
5回答 すべてを表示
I can't fold my scooter no matter how hard I try?
After I'm done using my JD Razor 2000 scooter, I always try to fold it and stow it away in my garage. However, no matter how hard I try, I just can't get the darn thing to fold! Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
First, make sure you turn the Joint release latch located right behind the front wheel of the scooter.
As you turn the latch, fold your scooter and it should fold easily.
If it doesn't fold, be sure that the scooter's handlebars aren't blocking the scooter from folding fully and the alignment wheels at the bottom of the handlebars are in-line with the folding mechanism.
If your scooter is still not folding, it may be due to debris stuck at the quick release latch. To find out how to disassemble your scooter and remove the debris, visit the Quick Release Lever Replacement Guide on the JD Razor 2000 Device Page.
Visit the JD Razor 2000 Troubleshooting Page to find any more problems with the folding mechanism.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hopefully this helps!
http://www.youtube.com/watch?v=brvrzBIhT...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shane さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 4,202
