Is there any way to keep my button from sticking?
I spilled Sprite on my phone and now the home button sticks and does not work. Is there any way to clean or replace it?
If you spilled Sprite on the phone, the reason your home button doesn't work is most likely due to not only the button sticking, like you said, but the electronic part of the button inside the phone is also sticking or not working from getting wet. It is really a pretty simple fix though. All you need to do is replace the home button. Follow our easy guide and you should have it fixed in no time.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 180
