メインコンテンツにスキップ
Amazonから発売されたKindle Fire7インチのタブレットの改良モデルで、1280x800 HDディスプレイを搭載しています。2012年9月に発売されました。このデバイスの修理は直接パーツにアクセスできます。
Switches on but the screen does not power up
My daughters Kindle Fire HD will play the switch on music but the screen does not power up.
Any ideas would be gratefully received.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 22
38 件のコメント
Mine is like that too but I don't kno wat to do me and my mommy have tried most of the stuff on here
さんによる
Has anybody resolved this problem, I have tried resetting still not working it is telling me date and time an to swipe with two fingers but screens still off, I have taken the back off and disconnected the battery an again still not working, I don't no what to do, I have had mine 4 years now first problem I have had, thanks x
さんによる
I was reading on my kindle earlier and i left it on. Now it does’’t show anything. Though when i press the power button, it turns green and on charge it shows an orange light just fine but shows screen with just the back light and turns black again. Tried holding down the button, taking out and putting the batteries, and almost everything suggested online. Is the screen broken or its something else. Please help!
さんによる
will mine does not work screen do not turn on
さんによる
I can't get my black screen to go tried shutting down waiting
then turning on still doesnt work
さんによる
33件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
If suddenly your Kindle Fire won't work, then it's most likely locked up.
However, sometimes when it locks up you can't tell because the screen goes dark, either gray or black. It just looks like it's off when in fact your Kindle Fire is on but is stuck.
This is usually why a Kindle Fire won't turn on or charge, because it's already on but is locked up and thus won't charge or work properly
How to Reset the Kindle Fire
Resetting your Kindle Fire is actually really easy, just hold down the power button for at least 20 seconds.
Unless the screen is black or gray, you'll know when it's off. If you can't tell, just be sure to wait a full 20 seconds.
When you're ready, hit the power button to turn it back on.
Kindle Fire Won't Turn On
Kindle Fire Power Cord for Charging
If your Kindle Fire won't turn on it's possible the battery went dead (if it was left "on" too long).
Plug in the power charger and wait about 15 minutes to make sure it gets enough charge, and then try turning it on again.
If it still won't turn on, try to reset the Kindle Fire again to be sure it's powered off.
このアンサーは役に立ちましたか?
スコア 27
34 件のコメント:
I got it working right away. Thanks.
さんによる
imma try in and hopefully it works, ill let you know
さんによる
Omg thank you so much... This helped my amazon fire to restart and work right away.. Thanks once again.. BTW I had to created acc just to post this. Lol but it was worth it ..
さんによる
Works! Yay, thank you so much. I thought it was dead and could no longer get a return.
さんによる
Worked for me too! Thanks
さんによる
29件以上のコメントを表示
コメントを追加
If you see a black screen or if your Kindle is unresponsive, it may be out of batteries. Try charging your Kindle for at least one hour. ... If your Kindle’s battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power. If you have any problem then call me.
このアンサーは役に立ちましたか?
スコア 16
17 件のコメント:
My Kindle working. Thanks
さんによる
Thanks @bravomarshal , this was helpful for me.
さんによる
Thanks for the useful information. It's working for me.
さんによる
My Kind fire screen does not power up but this is working. Thanks Marshal
さんによる
My kindle is running fine now. Special thanks to the support.
さんによる
12件以上のコメントを表示
コメントを追加
Oct 24, 7:54pm
Hi Emilee, the only thing that worked for me was removing the battery and putting it back in. It's taped in and looks like it's not removable. I removed it anyway because I was fixing to just toss it out since I couldn't get past the black screen. AND I TRIED EVERYTHING BUT, prior to removing and re inserting the battery and its what worked, surprisingly!... Good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
How did you take the battery out safely? When I went to try to get mine out, the battery seemed to deform. almost like it's bendable.
さんによる
Please watch youtube video on how to disconnect battery and connect again and it does work!!
さんによる
コメントを追加
  1. Try to hold the power button for 15 seconds.
# If a Kindle neglects to do anything it might be totally discharged. Check that the charger or cable should not be faulty. A Kindle Fire significantly requires more current to charge it. Charge the Kindle for an hour or two and take a stab at driving it up.
  1. On the off chance that the charger and lead are OK yet the Kindle, despite everything won't charge then the odds are the Kindle has built up a flaw or the battery has fizzled. The first of these is almost certain since the batteries appear to keep going forever. Frequently the USB attachment splits from the circuit board. In the event that it's a dead battery then it can be replaced.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I just held the power button down until the grayish screen turned black ,then held the power button down again and it turned back on with Amazon logo then fire logo popped up. Almost panicked because it's my husband's Kindle and I was just trying to watch a show on Netflix when it tripped on me . SMH
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Date 8/10/2018 . Fire hd10 2017
I freaked out once the tablet went to a black screen from leaving it on. I knows it had plenty charge as it was over 70%. I read the posts and the method that was successful was to hold down the power button 3 seconds. Making sure it thinks is on. Then holding down 30 seconds or more (10 second method doesn’t work). As soon as the screen flick and showed fire, I shed a tear and kiss the tablet. This tablet fires my heart. Talk about material fellings lol.
Then it read updating storage device. Anyway This point the tablet was alive and save me from being bored waiting for my flight.
Until next time. Chao!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you Thank you Thank you! It was that easy. I’m back in business!
さんによる
コメントを追加
the kinda fair if it stop chargeing or the sceen gose back it might be because of the charger you are using and it you might need a diffter chargs
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My fire kindle 7.kids edition turns on however won't go past the black screen with Amazon on it
さんによる
コメントを追加
回答を追加する
andy さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 99
今までの合計 122,822
