Front LCD display no longer works
The device is able to power on and play music but no numbers or other information can be seen on the LCD display.
A possible fix could be as simple as turning the unit off and on again. To ensure that the device is fully powered off, remove any batteries from it before turning it back on. If the LCD screen still does not display information, the LCD display has most likely died. Fixing the device would involve a more complicated repair: replacing the LCD display. However, this is possible if you follow our guide on replacing the display.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 332
