How to Replace broken accellerometer?
Which is the procedure, if exist, to replace the accellerometer? and how much can cost the replacing parts?
Thank for your help!
Hey - what are you trying to do ?
You would have to identify the chip - search for a replacement or salvage from a broken board, and since it will most likely be a BGA package you will need a hot air rework station.
I would say a replacement should cost ~$15-$25 per chip
このアンサーは役に立ちましたか?
I ask - what are you trying to do - simply because its such a specific problem. How did you diagnose a broken accelerometer.
Maybe you should watch this first:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 995
