メインコンテンツにスキップ
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212回答 すべてを表示
New hard drive, still getting folder with?
I just ordered a new hard drive after it appeared my old drive was corrupt. Now that the new one is installed, I still get a folder with question mark at startup and I can't boot from an extra drive with OSX on it. Startup manager won't pop up. What can I do? Is there something else wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Try booting from your install CD/DVD. The new disk is blank - has no startup folder on it. It may not be correctly formatted for your machine (GUID format).
If you have another Mac (or a friend with another mac) you might:
  1. Put the new drive in an external case and fomat/clone a system folder to it.
  2. If the other machine can be put into target mode you could boot from it and use it to format the drive and install an OS on it.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
adamvieira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 110
