メインコンテンツにスキップ
The Motorola C261 was announced in 2005 and released in 2006. This phone is now discontinued. The phone repaired in this guide is further identified by model TFC261B.
2回答 すべてを表示
Why won't my phone turn on?
My phone won't turn on when I try to turn it on. There is no indication of power or activity after using the power button like normal. The problem is consistent and more attempts show no changes to the result. What might be the cause, and what can I do about it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Here are a few simple ideas that you can use to diagnose your issue:
  • Make sure that your phone has been properly charged.
  • Make sure that you are holding the power button for at least three seconds.
  • Make sure that your charger is working by testing it in different electrical outlets.
  • Check the electrical connections at both the phone and the wall.
These fixes may seem ridiculous but are often overlooked. If none of these options get your phone to power up your battery may need replacing. See the troubleshooting page for this device to learn how to replace the battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alexander L さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 137
