メインコンテンツにスキップ
Released 2001 by Thomson multimedia Inc. The RCA RP3715A is a radio alarm clock equipped with AM and FM radio frequency reception, an audible alarm clock function inclusive of snooze, nap, and sleep settings. This device has a memory holding system which is powered by a 9-volt battery.
4回答 すべてを表示
Why does my device produce no sound from the speakers?
No sound comes from the clock's radio function or the clock's auditory alarm function.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
If your volume is on and you can't hear the device the problem might be with the speaker. The speaker might have a tear. Replacing the speaker and also making sure the wiring is properly attached should ensure that you hear sound. If the device rattles make sure the screws holding the speaker in place are not loose.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
joseph さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 634
