Why is my tablet not turning on?
The tablet will not turn on. The screen stays black even when I press the power button after the tablet has been plugged in to the charger all night.
There are a few reasons why your tablet is not turning on including charger or battery malfunctions or the display may not be working. All of these issues are addressed and proper solutions are provided here on our troubleshooting page.
If the issue requires the battery to be replaced, here is a simple, easy to follow guide to lead you through the steps.
このアンサーは役に立ちましたか?
Looking to replace the charger port. Need part number to order replacement. Will follow U-tube instructions. Requires soldering skills :(
1.) I have already factory reset all the software.
2.) Already replaced battery with new one.
3.) Still can't get the thing to charge.
4.) Tried other chargers in same port.
Must be hardware related to the port itself.
KD
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,942
1件のコメント
I changed the battery and I try with recovery mode but the tablet not turning.
I verified with tester the correct volts on battery and USB charger, it's right.
I think that the possible cause is the taste on off. I have not answer to this question. Have you can help me?
Kenzo さんによる
