メインコンテンツにスキップ
Button makes electronic "click" sound when pressed
Here's a weird one -- I've got a 14" iBook G4 that makes a subtle electronic click sound when the button is pressed. It also makes this sound when the space to the LEFT of the button is pressed, like just pressing on the plastic of the topcase is triggering it as well. Very odd, I know. The sound almost sounds intentional, as if it's supposed to happen, and it's very subtle and high pitch, like two pieces of glass or metal lightly tapping. It's kind of pleasant, actually. It's definitely an electronic sound.
Anyway, I've had a few machines do this over the last couple years, and while it's not a huge horrible problem, it would be interesting to know what causes it. The machine has a fresh OS, so it's not a tweak to the button settings, etc.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Does it sound like an HDD sound?
さんによる
when you say "button", are you talking about the power button, or the trackpad button?
さんによる
コメントを追加
4件の回答
ベストアンサー
The way the power button is installed I would suspect a mechanical rubbing and release is the cause of the click. Pressing on the top case would have a similar result I should think. Ralph
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
He says it's definitely mechanical
さんによる
コメントを追加
If you look in System Preferences>Track Pad>Clicker you'll find the solution. Clicks like the clickwheel on an ipod. OR not, depends on the setting.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
That's a good thought, but I remember checking that, and it wasn't it. The clicking didn't happen all the time. Since I know it wasn't the hard drive either, I can only assume it was some kind of electrical flaw in the topcase. Ah well, I'm not going to lose any more sleep over it unless I come across a similar machine.
さんによる
コメントを追加
Maybe a simple PRAM reset will work.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Tried that, good idea though.
さんによる
If it's definately hard drive then verify/repair/replace
さんによる
I'm not convinced...it makes the sound when the button is pressed...I've never known hard drives to make a distinct sound on command.
さんによる
I have a feeling that he needs to open it up and take a look.
さんによる
Sorry, I meant to say it's definitely NOT the hard drive, but I forgot the "not". :-) It was a minor issue and I sold the machine, so I'll have to wait for the next one to solve the mystery. Thanks for the brainstorming though!
さんによる
1以上のコメントを表示
コメントを追加
Now that my trackpad stopped clicking by itself, I'm not sure what's going on. It seems the button to select" clicker" in system preferences enables the trackpad to behave like the select button below it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rdklinc さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,893
