メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mazda Protegéの第6世代。Mazda FamiliaやMazda 323としても知られています。5ドアファストバック仕様はFamilia Astinaや323Fと呼ばれていました。
When pushing the gas peddle for the first time...
My Mazda Protege 91' started to go-stop go-stop when I first hit the gas peddle. Once already moving - no problem. I also noticed that if I am stopped up-hill, the engine cuts off (won't remain idling) + if already in motion (while up-hill)-the back and forth motion won't stop, and it would fail to climb up-hill. I replace the fuel filter, spark plugs + cables and there's no difference for the better.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Thank you, everyone, for responding. It turned out to be a failing timing-belt. It eventually quit altogether. I'm now looking to see if the valves are bent or not. Either way - it's time for a new car... Thanks again.
さんによる
コメントを追加
3件の回答
ベストアンサー
You replaced the fuel filter--did you notice how good was the flow of fuel? I think I would check the fuel pump as the next possibility to cause your problem. You can test it without replacing it--check your owners manual for the method in your vehicle. You might also have debris of some sort in your fuel tank blocking fuel pickup intermittently. I think your basic thought is good and the problem is in the fuel delivery system somewhere. Good luck. Ralph
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ I definitely agree, this sounds a lot like a bad fuel pump to me.
さんによる
コメントを追加
I agree it may be the fuel pump, but there may be more than one filter to change! A car that age should still have a good pump, but you never know. Clogged fuel injectors can give the same symptoms as well. My first step after double and triple checking for a second filter would be to add a bottle or two of injector cleaner - I like Techron, it works well. See if that helps.
Simple fuel pump check would be to disconnect the fuel line at the engine- while the engine is cold, preferably after it has sat all night. then stuff the end of the hose into a bottle (I use a 2 litre lol) and observe the rate of flow. If it looks normal, you still may have a problem with pressure. Many auto shops can check your fuel pressure for you for not much $$. I d have them do the checking, unless you have a buddy with a fuel pressure gauge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Also...
I know in 1990 Mazda still used a disributor cap and rotor.
I can't find any info in my car library that tells if it does still in 1991.
If so, replace them. Double check all wiring to the coil pack if it does't use an old fashioned distributor.
My bet is that it't injector or fuel pump related, but those are other things to look for. Best of luck! Tom
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 1,464
