メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
317回答 すべてを表示
Static on screen when waking up?
A few times over the past week when I've woken my Mac Pro up from sleep, the monitor will show nothing but multicolored static against a white background. I've restarted and the problem disappears. But it's a little disturbing.
I've found a giant thread on the Apple boards on the subject -- http://discussions.apple.com/thread.jspa... -- but no one there seems to know the cause.
Thought I'd throw it out the ifixit community to see if anyone's figured this one out.
I'm running 10.6.2 and have an ATI Radeon HD 4870 graphics card.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
If you are still under warranty, see if you can convince Apple to replace your new video card. You can perform the swap yourself if you are confident with a screwdriver.
Contact AppleCare at 800-275-2273, or try online selfservice at http://www.apple.com/support/serviceassi...
You can also bring the unit in to an Apple Store or AASP. If you can take a picture of the screen when it is displaying the symptoms, bring it with you to aid in proving the issue. You will need to do this with a digital camera, I don't think your will be able to do a screen shot :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
why is the power supply on the macpro dual xeon processors so high than the HP workstation which only contain 650 watt pSU the mac pros from 2008 to 2012 say they contain 980 watt power supplies units, which I would think is a electrical risk. what can I do to correct this issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mister790 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,788
