How Do I Stop the Gas From Venting Down the Barrel?
My gas vents quickly down barrel as soon as the marker is gassed up. What is wrong here?
The most likely cause of this is one of the O-rings in the bolt is dirty or damaged. Nothing to worry about, but you may need to replace a couple of them. Look over here for our O-ring replacement guide. Once the bolt is disassembled, check all the O-rings for damage. Replace any that show damage, lubricate all O-rings, and reassemble the bolt.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 212
