メインコンテンツにスキップ
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
Why is the trigger on the saw sticking?
When I press the trigger to turn on the saw, the button seems to get stuck frequently. What can I do to solve this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Either it's choked with dust/grease/debris or it may be broken inside (lock button or actual micro switch).
You'll have to examine it closely - use some spray cleaner, if that doesn't work take it apart and check the trigger for damage.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Riley Hilliker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 180
