メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
Keyboard stopped working afte I opened laptop
Husband spilled coffee on laptop, I took it apart to clean. By accident I ripped track pad ribbon and the keyboard doesn't work. What should I check? Should I just replace the entire keyboard? Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Examine the rest of the inside of the machine for spilled liquid and corrosion, burn marks or swollen components (use no forced air) it may need to be cleaned and completely dried before starting.
The worst thing you can do is apply power to a wet machine, or, leave the battery and charger connected until you know it's dry.
Follow the tags at right to see what you could be in for.
Generally replacing the entire top case is easiest in a case like this.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ingrid I Caito さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 74
