How do I get this version Ipad out of Recovery Mode?
mMy Ipad has been stuck in recovery mode, ive watched youtube videos countless times trying to get it out but, nothing seems to work!!!!
I am also having the same issue. I downloaded the update on my phone, it then told me to connect to itunes and when I connected to itunes it began telling me that my phone was stuck in recovery mode. It just keeps going through the "recovery mode" motions, but not actually getting to the installation process. Any suggestions how to stop the cycle? I uplugged my iphone at one point from itunes and did a manual shut down/restart of the phone but it just cycled through again.
Finally I got a tutorial named: iPad Stuck in Recovery Mode
You can have a try and hope iPhone Data Recovery can help you.
このアンサーは役に立ちましたか?
How to get iPad out of recovery mode
1. Please launch the iPad Recovery and connect your device to PC via USB cable.
2. If you are Windows users, the following window will shows to you. Please click the "Restart the device" button to get iPad out of recovery mode.
3. After a few seconds, your device will be back to normal after the restart.
このアンサーは役に立ちましたか?
You can follow the Apple Support which would be help of the stuck, and some will be fix the problem.
https://support.apple.com/en-us/HT201263 Remember to update your iTunes or reinstall it.
If that cannot work on your iPad. You can try this. http://www.pcadvisor.co.uk/how-to/apple/... It's about to get iPhone out of recovery mode, maybe the same as iPad.
The last method is to use recovery tool like the FonePaw iPhone Data Recovery and Wondershare which can solve the stuck problem and recovery the deleted data from your iPad. I used the former to fix my iPad 3, and they have a tutorial about fix iPad stuck in recovery mode. You can find on the website of FonePaw.
このアンサーは役に立ちましたか?
Download tenorshare reiboot, free app online. Works most times. Simple and easy to use.
このアンサーは役に立ちましたか?
Have you tried program "Tinyumbrella" it gets apple device that are stuck in recovery mode. Also have you tried to update your iTunes and make sure you're running the latest iTunes.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 640
