メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Can I upgrade the display to 1920x1200?
I've read about people replacing their MacBook Pro LCDs with non-Apple LCDs of higher resolution, and have not been able to find an guide on this particular model. How can I find out which key specs are relevant for compatibility? Obviously the size would be 15.4", but how about LED vs CCFL? or connectors? plastic frame? etc…?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
最も参考になった回答
I have done it.
Work in progress pictures of the MOD
I took an WUXGA panel from an IBM T61p computer, modified the EDID EPROM on it a bit, and the computer would talk to it.
I wanted to mount the panel on my A1226-machine, so the LCD cable and all would not be a fit, so i got an Display cable from an A1150 (1Gen Macbook Pro) and a Display bezel from an A1150 too.
With these parts you can mount the panel in the case.
But there is still som backlight to figure out, so i got myself an LCD panel from the A1226-model with LED backlight (broken panel, 15$) and ripped off the LED's and put them in the T61p-panel instead of the CCFL tube.
You need to solder the LED strip's 7 connection to the LED inverter in the A1226 and i would not advice anyone to undertake this unless they are an expert at soldering.
// Per.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Nathan,
Here is the link to your question on LED vs CCFL.
http://www.engadget.com/2007/06/06/MacBo...
I would forget about moding your clamshell.. Wast of time and money.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hey guys!
I have a Macbook Pro 17" (1680 x 1050) late 2007.
I would like to know if it is possible to replace the display of my MBP by the high res display of a 2007 MBP 17" (1920x1200) ?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Good news!
I changed the panel and it worked!
So for all of you who want to upgrade their display,
it is possible!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes but how?
さんによる
Where did you purchase your high res display? Was the display cable the same as the one for the 1680 x 1050?
さんによる
コメントを追加
Wow, now that's a mod and a half. If I knew what you were talking about, it would sound like fun. I don't even want to ask what you might charge for a custom install like that. Anyway I think you answered my question, which, at my technical skill level, I will have to live with the basic resolution. Thanks for posting and sharing the pics!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I really want to know if it's possible just to order a replacement 1920x1200 panel from the 2010 Macbook Pro to a mid-2009 macbook pro. Nobody seems to have tried it. Even the mod sites or repairs sites.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It won't work on the machine in question.
さんによる
コメントを追加
回答を追加する
Nathan Wauk さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 11
今までの合計 8,880
