メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Earpiece does not work, speaker and earphone are working
The earpiece speaker on my iPhone 5 does not work, and I have tried a couple of solutions, but none of them have worked yet. The sound just went out one day with no indication that the speaker was going bad.
First, I replaced the earpiece speaker and that did not resolve the issue.
I also replaced the entire display assembly because there was a small crack on the screen that I needed to fix anyway. The display assembly comes assembled with a front camera, earpiece speaker, and home button...
Anyone have other thoughts on a possible solution?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Is there anything stuck in the headphone jack?
Have you backed up the phone, and then reset the phone to factory settings and tried to use the speaker before restoring your backup?
Beyond that it sounds like it might be an issue with the logic board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The headphone jack is clear and I did try resetting the phone and tried to see if the earpiece would work before restoring my phone, but that didn't help.
さんによる
コメントを追加
First, check if you did some weird setting.
And then, if your front camera and light sensor work well? The earpiece speaker works by connecting with two metal contactors on the front camera flex cable. If the camera and the light sensor all failed, that's either the problem of flex or front camera FPC connector.
As for you have replaced with entire display and still not working, so it's more likely the problem of FPC connector or motherboard. To check if all the pins of FPC connector are well.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What's the FPC connector and how do I check the pins on it?
さんによる
コメントを追加
回答を追加する
piki24 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 432
