メインコンテンツにスキップ
The LG G Watch is an Android Wear-based smartwatch announced and released by LG and Google on June 25, 2014.
13回答 すべてを表示
Why isn't my battery charging?
When the adapter is plugged into a working outlet and the watch is docked onto the charging station the watch does not "wake" and start booting up which indicates that the battery is charging.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
If the device does not detect the charging station when properly docked it is most likely due to a common issue with the charging pins. The charging pins on the LG G Watch easily become corroded when they come in contact with sweat or water. In this case the charging pins will need to be replaced in order for you to charge your LG G Watch
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
how and where they can be replaced
さんによる
コメントを追加
Called LG, they said they do not sell internal parts. So unless you are an authorized repair center, forget it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I think it's unacceptable that LG won't service a watch which is less than 3 years old.
さんによる
コメントを追加
回答を追加する
Deja Miller さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 719
