Why is my touchpad not responding anymore?
The touchpad isn't responding to anything right now but I can use a mouse in the USB port. How can I fix the touchpad?
Does your laptop have a keyboard shortcut that disables the touchpad? I think off the top of my head Toshiba uses the Function + F9 key to turn on and off the touchpad. Some even had a button right next to the touchpad that performs the same function.
このアンサーは役に立ちましたか?
Go to Mouse settings>touchpad >additional settings on the right side>>Advanced>advanced featured settings>device select>touchpad>>apply
このアンサーは役に立ちましたか?
You may need to update the touchpad's driver. Which can found here at the Toshiba Software & Support page
このアンサーは役に立ちましたか?
That’s a good idea, but that’s not always the case.
One of the issues is that your laptop is old and the laptop dies / runs out of battery, so the mouse pad goes filty and stops working . The only way I’ve found is that you use a usb and connect and mouse to the laptop.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 8
過去 30 日: 37
今までの合計 10,971
