メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
strange colors randomly and camera screen shaking and camera works
https://www.youtube.com/watch?v=fcQaCkGu...
Iphone 4s, when in camera/video menu the image it's shaking and colors from the screen changes to something like windows error 256k colors sometimes after i whipe to unlock it the screen goes black or white, or from normal colors it goes to strange colors. They will reset tough if i lock it, all these symptons are randomly, also when in home menu 1 or 2 application from the left side has their text shredded from the far left side of the screen. If i`m on the message screen everything works, no strange shreds or tears, no color changing, no white/black screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
You could first start by restoring the phone to rule out and software bugs.
Did this happen after a fall or repair..
If the restore has no affect then it's most likely a faulty screen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My iphone4 did this, and eventually the screen quit working altogether. I took it to a repair shop and they said the motherboard had water damage.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Unfortunatly i don't want to turn it off because it won't turn on. It will do like this Strange circle on display and i have minimum chances of starting it back acgain.
Hmz water? I don't know here it gets the water since i never travelled in rain with the phone, and beside it does this for like 2-3 months when it was summer and hot+dry not wet and cold.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,101
