メインコンテンツにスキップ
2013年10月22日に発表され、11月12日に発売されました。iPad mini 2はRetina Displayが搭載された iPad miniとしても知られており、小サイズ7.9インチのフォームファクタのiPad Airに全ピクセルが詰め込まれています。
426回答 すべてを表示
My iPad mini retina is self touching and not responding after replacement.
I replaced my digitizer 1 month ago i got a 20$ screen on amazon and now my iPad has "dead spots" like i can't type in the keyboard the letters t n and w and my iPad goes crazy and punches random things in keyboard it goes into apps by itself. Please help any would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Chances are you never covered the gold contacts on the screen and it's shorting against the metal frame it's always that..
As for the dead spots it's either damaged or the cable was damaged when laying the screen flat..
Best screens for the iPad mini is a genuine Apple screen because you will never have the problem with the ghost clicking
Cheaper is not always better
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What do you mean "the gold contacts on the screen"? Is it along the whole digitizer or down by the home button? Do you have any images I can see for reference? My screen is also jumping around and some spots on the digitizer are not responding. Also I slide to unlock and it works fine, then there is suddenly no response.
さんによる
I removed the digitizer and even if I fold it back, the screen keeps jumping all around like random touch. So it should not be the digitizer is not taped. How do I check it the flex is creased?
さんによる
コメントを追加
Thank you! I will probably order one from ifixit and if that doesen't work im gonna have to get a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would be thinking creased digitizer flex. Make sure the flex bends in toward the LCD as in the original. If you allow the flex to stick to the adhesive, it will form a crease on the frame when you press the screen into place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gabriel Perez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 1,881
