メインコンテンツにスキップ
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
412回答 すべてを表示
締切られた回答
Start and Select button replacement
So my start and select buttons cracked, no problem went and got a set from my local repair store for $5, now the problem I'm having is that when I install these new black start and select buttons, both like to get stuck down after I press them once and they don't go back up. My home button does not do this even with the replacement button. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I was actually just having the same problem, which is how I ended up stumbling upon your question. After a lot of frustration, I realized that the two little tabs on the rear of the button were being blocked from sliding all the way into their receptacles because a little bit of plastic had bent to block the opening. Once the openings were cleared the button worked properly again.
Hopefully this photo makes things a bit clearer: http://i.imgur.com/SuYXBe5.jpg
Just make sure there's nothing blocking the slots circled in red.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
THANK YOU SO MUCH, my god this was the most frustrating thing ever and now it's fixed thanks to you! THANK YOU. :O
さんによる
Haha, I know the feeling. I nearly drove myself mad spending hours trying to reseat the buttons over and over again before I realized this.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,139
