メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
締切られた回答
Re-sticking wires inside of Retina MacBook Pro.
I attempted to replace my keyboard, and I was wondering if it were possible to stick the various parts back down like they originally were to make it less obvious I gutted the machine.
Including cables, rubber parts, the microphones, and the battery warning sticker. I'd like it so that if I have to get it serviced, it won't be immediately obvious that someone's been inside.
Especially the microphones, that part isn't sticking down properly anymore.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If you've attempted (but not completed) replacing the keyboard alone on your machine. . . they'll know.
If you've pull off connectors, they'll know - connectors are not "stuck" on the board they are soldered as part of the assembly. Adhesives do not conduct current.
A dab of rubber cement or a thin coat of automotive weatherstrip adhesive will hold wires, and the microphones back in place if the original "sticky" is insufficient .
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
The reason I didn't complete the job was everyone was saying it was impossible to get the rivets back in, so I reassembled it and ordered screws from eBay. When I get them, I'll try again.
Don't worry, I didn't pull off any connectors, the only mistake really was that I forgot to disconnect the backlight before removing the logic board, and I suppose removing a part or two I didn't need to. Anyway, I tore that cable. Luckily the new keyboard also came with a backlight of its own.
Will the rubber cement be significantly stronger than the original "sticky"? I'd want it to be possible to remove the parts without ripping them.
さんによる
If you use one (not three) coats of auto cement it will not hold as firm as on automobiles. Silicone also works. Strong is a relative term... how many times do you anticipate stripping that box? Another alternative is double sticky tape, either the light (paper), or the thick (carpet/rug) holding kind.
さんによる
I don't anticipate stripping it again, but I want it to be possible without causing irreversible damage. I figured as close as possible to the way it came out of the factory was a good ideal for the adhesive strength. I do have silicone from a less invasive repair attempt. It's a sealant thought, not "glue". I guess I can try that.
Realistically, what would happen if I took it in for service for a different problem? Would they tell me I don't owe anything, but then notice the undocumented work, then demand the money before they continued the repair?
さんによる
I don't work for Apple - major mucking about inside generllay will void your warranty.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 97
