メインコンテンツにスキップ
The Bissell ProHeat 2X Cleanshot is a carpet cleaner designed by Bissell.
12回答 すべてを表示
I need the hose configuration for inside the unit.
I need a schematic of the interior hose configuration, i took it apart to clean & forgot how to put back can you help please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
3 件のコメント
Please describe(or send a photo of) the area you require guidance and I'll create a tear-down guide for you.
Kind regards
Panshaker Ross
さんによる
I need a hose schematic of a bissell 9200 pro heat
さんによる
@gary4851 You will find what you need here --> https://evacuumstore.com/images/proheat-...
さんによる
コメントを追加
6件の回答
最も参考になった回答
can you show me the hose configuration for inside the unit I took it a part to clean it and can't figure out how the hose go
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Here's a picture of the interior of a Bissel ProHeat, I hope this helps
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
No es la misma el modelo mío es 9200
さんによる
I took off the hoses from the front not the back can you send me a picture of the front
さんによる
I think I have a solution for you in the form of a Service Center Guide.
さんによる
I'm in the same predicament! I took off hoses since all were clogged and now I cannot figure out how to put the hoses back together. Is there a schematic somewhere? Its a Bissell ProHeat and the tubing coming from the hose attachment within the case is what I cannot figure out how to reattach and where?
さんによる
コメントを追加
Kind regards Panshaker Ross
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Forgot how to put the hoses together to my Bissell ProHeat complete Pet 2x meet the front of the vacuum cleaner not the back
さんによる
コメントを追加
This may help you. There are schematics for hose configurations for several models which are very similar. They do not show the hose configurations for the clean shot nozzle but it is easy to decipher on your own Brain Power.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
If you have a Service Center Guide for the Bissell 9500 ProHeat 2X Clean-Shot I would very much like a copy of it myself. I also have this machine and have it working again except after everything is closed back up. Somewhere inside something is binding (suspected) but I can not locate what it is. Any thoughs will also be well taken. Short of a laser leveling device casting a light on the area to get everything below a specific level I am out of ideas. These machines are JUNK was the conclusion I came up with after going inside.
さんによる
Thanks Monty this is the same manual that I found once I sat down and actually started doing my homework, I have the machine back together and working something that the sweeper repair place couldn't do
さんによる
コメントを追加
i need hose configuaration for a bissell pro-heat carpet clean
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Me too. I cleaned the interior hoses that were clogged and now I have one hose that I don’t know where it connects to!
さんによる
コメントを追加
Because i took it apart and it took awhile to get the part i need and im a little lost about it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My bissel has the indicator that spins on top of the switch s
さんによる
コメントを追加
回答を追加する
Pat さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 26
過去 30 日: 75
今までの合計 6,240
