メインコンテンツにスキップ
The Commodore 64 was released in August 1982 and was met with huge success. In March of 1987 the Commodore 64C was released.
7回答 すべてを表示
Is it possible to connect the C64 to a flat screen TV?
I have a C64 and I want to connect it to my flats screen TV. My TV has composite jack.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
選択されたソリューション
You first have to make sure your LCD/flat screen has either a composite or S-video jack. It would be ideal for your LCD/flat screen to have an S-video jack because its easier to use S-video cables to connect the C64 to the flat screen via its 8 pin video port. The tools needed to make the LCD/flat screen TV to C64 connection includes: a 5 pin-adapter (which converts the 8-pin video cable connected to the 8-pin port of the C64 device into a 5-pin cable which is required for newer TV models). A SCART cable is needed in conjunction with the S-video cable. Any of the old C64 cables used with 5-pin adapter can will also work. I dont recommend using a SCART adapter with the S- video cable because you probably wont get video. Also its possible to connect your VCR to your C64 and connect your VCR to your flat screen which seems to work just fine. Another quick fix is just using S-video to HDMI converter.
Here is the link: https://www.google.com/search?hl=en&outp...
Hope this helps.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
just use a SCART lead
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here is what i have set up right now:
My TV / C64
I used a VGA to C64
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you do not have composite AV ports(even though you do), buy an AV to HDMI Cable.
That way, you can connect it to any modern TV.
I hope you find this information useful.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Adam Kowaleski さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 43
過去 30 日: 219
今までの合計 20,828
