メインコンテンツにスキップ
An entry level smartphone released in April 2014. Available in black and white.
135回答 すべてを表示
My Blu Studio 6.0 screen broke, how do I fix it?
My phone fell down with the screen facing the floor and got cracked, the tactile still working but is really hard to see behind the cracked screen. How do I replace the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 85
11 件のコメント
I have a blu studio 6.0 hd d651 it fell on the corner and it cracked. I can still see everything but the touch is messed up. Do I need to buy a lcd and glass replacement or just the glass?
さんによる
I have a 6.0 lte done the same thing
さんによる
Ok i got a blu 6.0 nd drop it nd it wont come on..plz help
さんによる
I had a blu 6.0 it fell screen not broke but the back Button and home and menu buttons won't work. My husband's cell is exactly like mine but his seen is broke can we switch the screens from one to the other and make one good one
さんによる
I have a Blu Studio 6.0 HD d650a I dropped my cell phone and a cracked and broke on the touch screen did some things that do work like my power button and my volume buttons butt my touch screen cell phone does not let me log into anything when I touch it how can I fix this I need step-by-step Direction what do I need to get to fix my cell phone device death only three buttons that works on my cell phone I don't have no problem with that is my power button and my up and down volume button those work pretty well I don't have any complains about that adjust my touch screen cell phone I dropped and they have to be cracked on my cell phone touch screen when I turn my phone on and try to touch the touch screen to log into anything like my things that added to my cell phone like in the Google App Store YouTube anything else that added to my cell phone I can't log into anything that login to their and I mean anything can you please help me and give me advice what should I do
さんによる
6件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
its really difficult to separate the LCD and the touch screen digitizer in BLU studio 6 HD d650a / d651u , I tried using playing card ,thinnest fishing line (very promising), to separate was able to remove all glass but realized that the lCD broke in the process
my recommendation is to buy online a lcd+digitizer+frame online then to fix this model phone will take exactly 10 minutes and will involving removing the screws in the back panel only
the lcd+digitizer+frame is approximately $65
regards
dan
このアンサーは役に立ちましたか?
スコア 11
6 件のコメント:
When i order my lcd+touchscreen+bezel(frame assembly) online how do I know its for my D651u???
さんによる
My name is sharon Jones my husband bought me a blue for my birthday at Christmas. I drop it and broke the gladd ans would like to replace the glass. ogv c.f. v
さんによる
Can you fix means lol
さんによる
After you take the back off then what's next
さんによる
my name is fidele my phone blu6.0 screen is broken
さんによる
1以上のコメントを表示
コメントを追加
you will need a new digitizer to fix the screen places will tell you to get a new LCD but that is not needed if the screen shows up
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Touch screen of my BLU studio 6.0HD D651u mobile phone is broken. Please help what should I need to repair it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here is the LCD with a Broken Digitizer in case someone with the digitizer wants to try and separate the LCD from it. The LCD ad is a "Or Best Offer". Make an offer. http://www.ebay.com/itm/271946932295?ssP...
The Digitizer is located here: http://www.ebay.com/itm/181794085093?_tr... if someone wants it.
You will also need the UV Glue to bond them together. Here it is on Ebay: http://www.ebay.com/itm/UV-glue-LOCA-Liq...
And you will need this: http://www.ebay.com/itm/Mini-Aluminum-UV...
Here is a video on how others separate the LCD from the Digitizer: https://www.youtube.com/watch?v=M2rHnk2C...
Hair dryer works very well. you need heat!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can buy the parts on ebay it's about 60 bucks but make sure you get the both the glass+lcd frame. Once you have the part it's very simple to replace it.
Turn off phone
Turn it to its back n take off cover
Takes off any screws you see
Then you take your nails or guitar pick n in between the screen frame container and the body and go around till u get it off (u can tell where they are both separate) just be careful around the power and volume buttons. U don't want to rip those off
Once that's done take off the the big black ribbon and a small ribbon, so taking off two (if u look at your new part you can tell which ones are they)
Now you turn it over n heat that sucker up n use the same guitar pic to go around to take off the glass u Goin to have to do it over and over, then once that is off u take both the Glass n lcd out n put in the new one (there is a bottom ribbon sort of a tricky fellow but u must plug it in as well u will know when u see it).
Then heat the glass one more time so it can stick to he glue again. Put it back together and your good to go.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My blu sreen broke has a long line running across it and i cant work the phone ...who can i get to fix it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to get the screen replaced from BLU service center or you can buy new LCD screen online and get it fixed from mobile repair shops. However, I will suggest you to contact service center once and ask for the solution for broken LCD display.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ernesto Diaz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 44,323
