My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
このアンサーは役に立ちましたか?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 1,716
