メインコンテンツにスキップ
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
How can I get the buttons on my radio un-stuck?
I pushed the pause button on my radio and now I can't get it to pop back out. I have tried pushing it several times and it seems to be jammed in a permanent downward position.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
ベストアンサー
If the button is stuck, try to use something small to clean around the button; it may have dirt built up around it causing it to be stuck. Use something small such as a paper clip or a cotton swab to clean around the button. If this does not work, you may need to disassemble the device. If you need more information, see the link here to our Troubleshooting page.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Brittany Patterson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 37
今までの合計 22,573
