メインコンテンツにスキップ
Why not update from 10.5.0 to 10.5.8?
Hard Drive crashed and inserted retail CD disk and ran utility indicated was not repairable. I tried repartitioned (journaled), ran verify and repair and indicated that the volume was ok. It Installed retail 10.5.0 properly. It then downloaded combined update of 10.5.8 but would not install indication that it could not install on the volume. I assume the HD is still bad or there is a software issue. I believe this is the same software CD I installed earlier on this machine. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You may not have enough space on the HD for a full install. Try a custom install and do not install language packs, printer drivers and fonts you don't need. That may solve your problem.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
clogsdon1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 86
