メインコンテンツにスキップ
1983年にリリースされたニンテンドーファミリーコンピューター(ファミコン)は、ニンテンドーエンターテイメントシステム(NES)のベースモデルです。モデルHVC-001
9回答 すべてを表示
Blown Fuse / Smoke on Famicom?
Hi All,
Excuse my naivety. I purchased an original Japanese Famicom in Super Potato, Tokyo recently for use in the UK.
At the counter I requested them to provide power supplies - I was provided an RF Switch and Japanese AC Adaptor (100V AC 50/60hz with 10V DC 850mA)
Upon returning, I purchased this RF Cable: http://www.ebay.co.uk/itm/RF-Cable-Super...?
So I hooked up the RF Cable (didn't use the switch), and combined a Travel Adaptor + The AC Adaptor I was supplied with the Famicom and immediately after switching on, I noticed white smoke coming from the Famicom and a pop/bang noise after 5 seconds.
After realising I should be using a step-down convertor or a plug with the current AC Voltage I purchased this and tried using it tonight:
http://www.ebay.co.uk/itm/151415102678?_...
Unfortunately, the Famicom now when turned on doesn't seem to emit any noises or sounds, and the temperature remains the same so I can only assume it's broken - perhaps I've blown a fuse?
What's the best thing to do here?
Option 1) The Famicom is dead, I should just give up
Option 2) Is anyone here based in London that could perhaps take a look at it? I'd be happy to pay for your time & parts
Option 3) Is it possible I've blown a fuse or something that I could fix myself in a straightforward way?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
Sounds like a blown fuse.
It's very easy to test for with a multimeter and is a half hour job. You need a 1.5 amp axial quick blow fuse. You can buy them on eBay UK for a couple of quid.
However, assuming it's the original model with hard wired controllers, you might find it difficult to get a TV that can tune in to the famicom RF Signal. I AV modded mine.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Pete Campbell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 22
今までの合計 2,635
