メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Keurig社製のプログラミング可能なコーヒーメーカーです。このコーヒーメーカーは、K-CupポッドとK-Carafeポッドを使用して、様々な温かい飲み物や冷たい飲み物を淹れることができます。 モデル番号:K2.0-400 シリアル番号:401.0200.1410931
Keurig 2.0 will not dispense water and make cofee
it lights up and sounds like its going to dispense water but only a few drops come out
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 47
11 件のコメント
Mine does this but the screen says preheating.
さんによる 共有
Me too. It worked this morning then tonight it stopped dispensing. Nothing was changed.
さんによる 共有
Mine says it's filling and the water pours out the bottom.
さんによる 共有
Mine is doing this. Heats up says it's dispensing very little comes out then it shuts off like it's done with barely doing anything???
さんによる 共有
Mine heats up, then starts to dispense water, and only a spoonful of water is ejected, and then it shuts off like it has completed a full cycle. But has not!
さんによる 共有
6件以上のコメントを表示
コメントを追加
24件の回答
最も参考になった回答
I brushed the needle area, unplugged, replugged, restarted, still did not brew. The water dispensed through the upper left plastic overflow nozzle;
I then took the reservoir off, cleaned the water suction water area unplugged, replugged in, restarted, still did not brew.
FINALLY BEFORE RESORTING TO TAKING THIS (&^%#$%^&&*APART, I thought ol' school methodologies, ( hitting the t.v. made it focus better........) SO, I unplugged my KEURIG, took the reservoir off, AND I turned the entire KEURIG UP SIDE DOWN OVER THE SINK, HIT THE BOTTOM WITH MY FLAT HAND TEN TIMES (10 X), THEN I TURNED THE KEURIG RIGHT SIDE UP, replugged it in, restarted, O M G!!!!!! IMMEDIATELY, ,,MY KEURG STARTED BREWING BETTER THAN THE FIRST DAY I PURCHASED IT YEARS AGO!!!!!!
MORAL OF THE STORY? SPANKING, SMACKING THE BOTTOM, HITTING BOTTOM IS LEGAL IN ALL 50 STATES AND IT DOES WORK! HAHAHHAHAHAHAHA- TEALE RHODES
このアンサーは役に立ちましたか?
スコア 27
45 件のコメント:
worked for me, too!!!!!!!
さんによる 共有
I can't believe it but this worked!!
さんによる 共有
I am having the same problem. It did not work for me.
さんによる 共有
I tried again but this time harder and it worked. Surreal. Thank you
さんによる 共有
It didn't work for me and I spanked it real good. :-) Thanks for the excellent idea!
さんによる 共有
40件以上のコメントを表示
コメントを追加
I have a different model, but the water reservoir is in the same location. After four years of no problems, the water output kept diminishing until it totally stopped. I searched for a remedy, but found none that worked.
You may consider this a little inconvenient, but it works perfectly for my Keurig.
When starting the process, remove the top of the water reservoir. After pressing the flashing blue light, the sound from the unit changes after about 2 or 3 seconds and when this happens, hold the tip of a finger over the nylon drain tube until the brew cycle ends. For some unknown reason, the air flow is expelled through this outlet, instead of forcing the hot water to make the coffee. Blocking the air forces the internal pressure to expel the hot water as it was intended to do. As long as this works, I will delay purchasing another unit.
Chuck Dimmitt
このアンサーは役に立ちましたか?
スコア 11
8 件のコメント:
Works Just like you said....
Betting there is an issue with the pump??? May disassemble mine and give it a good cleaning
Thank for the info
さんによる 共有
Thanks! Made mine work and it hasn’t been used much and was stored. Ran another cup through old pod and it sounded and worked perfect!
さんによる 共有
6 year old Keurig. Blocking that tube made it work great. Works now as before and I don't have to block the tube anymore. Thanks for the great tip!
さんによる 共有
Worked for me! Weird fix, but hey, glad it's working again! Don't need to block the tube anymore.
さんによる 共有
It didn't work for me, but I did see a little bit of water coming out of the spigot, tried it a few times more and actually did the "spanking it" thing and neither worked. Brilliant idea though, thank you!
さんによる 共有
3件以上のコメントを表示
コメントを追加
I have a Keurig 2.0 K500 and had the same issue but it is very very easy to fix! The part that you need came with the machine its in a small plastic bag and is orange with a clear plastic bubble on the bottom and also in the bag is a small piece of paper that shows how to clean the needle and unplug your machine. Good Luck!
このアンサーは役に立ちましたか?
スコア 6
5 件のコメント:
Thanks! Saved me another $250 was about ready to go buy a new one. Forgot I even had the orange thing.
さんによる 共有
Worked great.on mine thanks
さんによる 共有
Where fo u put the needle at where the pod goes
さんによる 共有
When I put a pod in water goes all over the plachave it 6 years but not used heavily. In plugged it while working in kitchen say 2 weeks water just goes all over the place and lot of grounds in cup
さんによる 共有
Thank you! This worked perfectly!!
さんによる 共有
コメントを追加
I had this problem too and thought it was fatal so I bought a new machine. the new machine came with a maintenance accessory (my old one did not!) The problem was simply a clogged needle. After clearing the needle with the maintenance item, the old unit worked as new. There was no hint of this accessory anywhere so was unaware of the clogging potential easily solved with the "maintenance accessory" that did not come with my original machine Shame on Keurig. Now I have two coffee makers!
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
the clog was coffee grounds, not from hard water deposits.
さんによる 共有
I used a straightened-out paper clip and did the same thing and it worked OK again for a few days (although it wasn't really stopped up). Then, I make the mistake of putting another of the BOLD coffee pods in it and it stopped putting out water again!! I don't understand why except it's harder for it to push the water through the pod, maybe?? I'm flummoxed.
さんによる 共有
donate your second one ?
さんによる 共有
Two spankings didn't work nor did giving it the finger. I realized I had a strong willed child, so I read further and found the cleaning of the needle. My Keurig is now very cooperative. Thanks SO MUCH!
さんによる 共有
The spanking work! LMAO. I Gave her 10 wacks. GENIUS!
さんによる 共有
1以上のコメントを表示
コメントを追加
I also was experiencing the same issue. We did not have the maintenance kit either. So, because I was not getting ANY action from the spout, I took the machine to the garage and blew, and blew and blew my compressor blower nozzle into the needle jet. After several attempts, HOT water started squirting out. My was definitely clogged behind the norm I'm suspecting, guess I'll just descale it again at this point. But to have some flow again and the compressor is encouraging.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I wish I had an air compressor!
さんによる 共有
コメントを追加
Mine had the same problem and Keurig said the first 2.0 models didn't come with the needle cleaner. She told me to use an open paper clip to clean it out. But it still doesn't dispense more than 2 oz. of water after cleaning it 6 times. And to think that when we received this model as a present, we gave away an original Keurig that never had this issue or required me to stand for hours pushing the button to get the descale solution and then distilled water through to clean it.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
My keurig will purge cold water/coffee if I plug it in, not push start, but hold the brew button for 3-5 seconds, and will keep purging until I release the brew button.. But if I push start, then push the red brew button, which then turns flashing blue, nothing else happens.
Since the pump is pumping to purge I'm thinking the pump works. Since water/coffee makes its way from the reservoir to the coffee cup while purging I'm thinking nothing is stopped up.
Anyone have an idea what's wrong and how to fix it?
さんによる 共有
Thank you so much. I was just about to toss mine into the trash when I saw your suggestion to clean the needle with an open paper clip. I didnt expect it to work, BUT IT DID!!!! My Keurig is back in working order just as it was before. THANK YOU!!!!
さんによる 共有
コメントを追加
My wife and I had the same problem with a clogged up Keurig classic 55 model, and it was only 20 days old. We called the online help line for Keurig support and got help from an agent who walked us through the entire fix. Took about 15 - 20 minutes. She told us we could also get similar detailed help from viewing their online videos from their website.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Hi Nancy,
Sounds like your Keurig is clogged. Try running a cup of white vinegar and water through it. You might also use a paper clip to clean out the spout and drain.
Hope this helps,
Dante
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Get the keurig cleaning tool if you dont have one. https://www.amazon.com/KEURIG-2-0-NEEDLE...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Mine does this too from time to time; the issue is that coffee grounds stay up in needles that dispenses water into the k cup. This is why I keep a sewing pin or sewing needle close to it and when this happens I use the needle to clear the water dispensing needle. When I do this I always run a 6oz cup of hot water and typically a ton of grounds will pour out clearing the water dispensing needle. Also to avoid this I’ve been getting into the habit of throwing out the used k cup immediately after making a coffee.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Another trick you can try is removing the water dispenser, dry out any excessive water on the area and hold a towel over the hole. Place your fingers on the air nozzle if you have one. The pressure will release water.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you. At this point I've replaced the Keurig with a French press coffee maker. The coffee is much stronger and I prefer it.
さんによる 共有
コメントを追加
I thought about the ‘spanking’ approach, but I applied some scientific method, and inspected the reservoir.. It turns out if it isn’t in ‘flush’ then you will get the symptom of poor flow. In my case, a part had broken off, and wedged in the ‘trough’ that the reservoir inserts, thus stopping it from being fully inserted.
After removing the object wedged in the place where the reservoir is inserted.. it was flush again, fully inserted, and I got normal working flow.
Conclusion: It’s quite likely that the spanking approach could have resolved due to the cause above. But instead of spanking it, just check your reservoir is fully inserted! :)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have a newer model it will dispense water but when I insert the pod 2 or 3 drops of coffee grains will drop in the cup. How can I resolve this problem?
さんによる 共有
コメントを追加
Clean the two needles under the cover with a bent paper clip, it’s clogged with ground coffee. And try dispensing again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The part where the water goes is cracked and the water goes all over my counter i need a new machine and i can't afford one because they are to expensive i have this one forever can you please help me
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Same problem and went thru everything before i did the simple thing. Turn it over and open head. Use paper clip or pin to clean out holes on both sides of the pin. The pin is hard to find ( use flashlight and you will see it). Put soda straw on what you cleaned, pinch bottom is straw to make tight seal and BLOW. You can tell it is clear. Turn over and try to brew. I think people have problems because they are not finding the pin that is clogged ( that was my problem). Hope this helps. I was ready to buy new water pump.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Love the idea about the straw and blowing out debris!
さんによる 共有
コメントを追加
I put my left hand in, then I pull my left hand out.
I reextend my left hand but this time I shake it all about
This hokey-pokey did nothing but entertain my dog.
Try running the KKKure-rig without coffee cup. I did that and then later it seemed to work.
The best advice, apparently, is to spank it…THE MACHINE! Oh come on, put that away ?
Upside down over the sink, shake it like a polaroid picture then spank it like Lindsey Lohan.
If not, look on craigslist. These are always available.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
That totally worked for me - a good spanking........
さんによる 共有
コメントを追加
Sounds like your Keurig 2.0 is dealing with a clog, likely in the needle or internal water line. Even though it powers on and makes noise, if only a few drops come out, the water flow is being blocked somewhere. First, try running a water-only brew cycle (no pod) after removing and thoroughly cleaning the exit and entrance needles with a paper clip or needle cleaning tool—gunk from old pods can build up there. Also, descale it with white vinegar or Keurig’s descaling solution if you haven’t in a while. If that doesn’t work, the internal pump might be failing or airlocked, in which case unplugging it for a while and then priming it (turning it on with the reservoir full and the lid open/closed several times) may help.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I completely agree both instructions. They are exactly what you should be doing according to the manual as well.
As a fellow consumer, if you Don't use pods and you put in your own coffee, I have learned that this makes your Keurig have a shorter life.
If you do use just the pods or very little home-coffee, I know several people that have had their Keurig's for a very long time and this is a monthly process to keep it running on the top shelf (like new). That time table also depends, of course, on how often you utilize the Keurig.
Best,
Andra R.
さんによる 共有
I know it sounds crazy, but this works. Take off the pot and any parts that can fall off when you turn the whole Keurig upside down. Turn the Keurig upside down and spank the bottom of the Keurig about 10 - 20 times. And when I say "spank", I mean spank it hard. Then try running water through it without a pod. You'll see a difference. If not, give it another spanking. I have done this to several Keurigs from Florida to the Bahamas to Greece and England. It works.
さんによる 共有
コメントを追加
Did that several times. Still not dispensing water.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I tried EVERYTHING. Nothing worked on my unit that was 2 yrs old. Keurig replaced mine even though it was past warranty. I will buy another if this second unit fails.
さんによる 共有
さんによる 共有
コメントを追加
Hi. Same here! My keurig just stopped dispensing coffee one day but it still sounded like it was brewing just only drops were being dispensed. After all, I just had to “bleed” the air out of the line. I got my fix from this site so I want to help you out too! It was a SIMPLE fix for me. When you remove the reservoir, to re-fill it with water and place it back on the base, check to see if an air bubble comes up indicating suction or pressure or something. Once I “primed” it (the system) by lifting up the reservoir and placing it down a few times a bubble came up and ta-da! It worked perfectly again. So now, every time I refill the reservoir I make sure to see a bubble come up. I had my Keurig for over 6 years and it still welcomes me every morning with a perfect brew of coffee! I hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Keurig 2.0 wasn’t pumping water like when it was new . Run vinegar through my machine and cleaned all removal parts with soap and water. I also cleaned the water feed tube ( sharp pointed small stainless tube) which punctures the coffee pod. I used a tip cleaner I had for a cutting torch. Small and flexible. Or you could use a small wire. I found out a drill bit 1/16 might work but not as good. My Keurig is back working about like new.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This issue is usually caused by a clog or pressure problem in the Keurig 2.0 water path. Most commonly, mineral scale buildup or a clogged needle prevents proper water flow, so the machine sounds like it’s brewing but only a few drops come out. A stuck check valve or failing pump can also cause weak or no dispensing. Start by cleaning the needles and running a full descaling cycle; if the problem continues, the water pump may be failing and would need replacement.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Please indicate when your answers, like this one, are AI-generated for the benefit of those who may think you actually know something about the device.
さんによる 共有
コメントを追加
It sounds like it's going to work hear it running but no water comes out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I’ve done ALL the things everyone commented several times! I thought for sure when replacing the reservoir and seeing the bubble several times there was grey cloudy “stuff” that came out also so I thought that would fix it but when I plugged it back in all the lights were on and no matter what I did they would not go off! Any suggestions?
さんによる 共有
コメントを追加
Hi there.
I think either it has an air bubble in the water line or the coffe grounds are caked in the hole puncher where there water dispenses into grounds.
Prime the water reservoir by lifting it up and down a few times until u see an air bubble. You have to watch carefully. Sometimes it’s hard to see the air bubble. This works for me most of the time. I had my keurig for 11 years!
Once I had to use a tooth pick to clear the grounds from the hole puncher.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Lol! I have the exact same problem with the system making the sound like it will dispense water but nothing but trickles of water. At first I used a push pin since I couldn't find a paperclip in my kitchen but it was too short. At least a little more water came out but not working properly. My husband eventually found a paperclip. I took the whole machine to my sink, turned it upside down, used the paperclip which went in further, then I decided to "spank" the machine a couple of times. We thought "that wouldn't hurt". We put everything together, add water and low and behold, it worked perfectly. We had a good laugh. I think it was because of the grinds that came out but we'd like to think the spanking had something to do with it. We decided to allow the descaling process before we have our next brew. Give it a try!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
nancy martin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 52
過去 30 日: 129
今までの合計 150,731
