メインコンテンツにスキップ
モデル番号はA1199で2、4もしくは8GB容量
Why will iPod not respond to PC via USB?
I have several iPod nano 2G's that don't respond to a USB connection to a PC, but will respond when connected to the firewire port. Of course I can't sync the iPod with the firewire connection, but the batteries charge and the iPod comes to life.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Ken, I know that is an old question, but it never got resolved. Anyhow, if you iPod charges on Firewire but not via USB, change the battery. It sounds like you battery needs the extra power supplied by a Firewire port, in order to charge. Hope this helps :-) even so it is almost 2 yrs later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I found a very simple fix. I know this will sound silly. But i had the same exact problem and all i did was blow into the connection port of the ipod.. Then i plugged it in and it worked. I tried everything else for days and the thought of those old nintendo cartridges came to mind.. I thought ha wouldn't hurt to try.. I was blown away man But it worked! :) I'm syncing my Nano as I'm typing this. Try it, Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ken さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,407
