メインコンテンツにスキップ
ディスク・スペースが足りないですか? バックアップソリューションが必要ですか? 外付けドライブは、オフィスや外出先で追加のストレージを提供します。 このページで修理する方法を学べます。
334回答 すべてを表示
Why external hard drive not showing up in my computer?
My 320 GB Seagate external hard drive is detected but not showing up in my computer. What should I do?
In disk management it shows up as 'unallocated'. If I initialize it, will I lose all data on the drive? It had 4 partitions.
In Device Manager it gets detected.
In cmd> diskpart> list volume it does not show up.
In My Computer also it does not show up.
Even BIOS recognizes it.
What to do? I don't want to lose any data on the drive. If I initialize it in device manager will I lose data?
I was installing window XP on my computer, usually I remove the external drive but this time I did not. The external drive was shown as 4 drives in partition manager during installation. But the installation failed. The next time I was installing windows again, the external drive was shown as 1 single unknown or unrecognized drive. I'm not sure if it was unknown or unrecognized. I'm sure I didn't format it. So what I need to do now? I don't want to lose any data.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Many reasons can lead to this situation, such as faulty drive, virus attack, hard drive hidden, etc.
In my view, it is more likely that the external hard drive is problematic, drive hidden or partition lost. To fix it, you can choose some technical tools for help. This tutorial may be helpful: https://www.partitionwizard.com/partitio...
By the way, you could consider upgrading your os because some programs are not compatible with Windows XP nowadays.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sherdil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 266
