メインコンテンツにスキップ
The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
52回答 すべてを表示
cold water wil not come out
the water will not come out ,the green light stays on all the time
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント:
Mine isn't working, either!
さんによる
I am getting hot water out of all taps even the cold one.
さんによる
コメントを追加
1 件の回答
I have an Oasis water cooler and just encountered the same issue. It turned out that the water in the tank had frozen. I searched all over for a manual and the only one I found was useless. I called the dealer and they said, "Unplug the unit, wait for it to thaw, then plug it back in." (Great solution, unless it just happens again and again!) So I asked, "what if it keeps happening?" They told me to turn the thermostat down (clockwise), so I thanked them and went to do that.
Surprise, I couldn't find a thermostat on mine. Yours may have one, though!
I suggest unplugging the unit for a while (giving frozen water time to thaw), then look for an adjustable thermostat. If you can find it, turn it counterclockwise a little bit. Then plug the unit back in and see if that takes care of the problem.
P.S. I realize you may not have waited 2 years for an answer, but, like me, someone may come along with a similar problem later. Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Mine is frozen too. This is the first time it's ever happened and I've had if for 9 years! I am unable to find an adjustable thermostat. So I'm going to thaw it out, plug it back in, and hope for the best.
さんによる
コメントを追加
回答を追加する
Lloyd Harter さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 84
今までの合計 6,241
