メインコンテンツにスキップ
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
screen problem unable to see picture.
hi this camera has been faultless upto yesterday. The camera turns on and I can see all pictures that I have taken. But when I turn it to take a picture mode I get up all the normal icons a light grey screen but no image. If I take a picture I get a grey screen shot.thought it was the lcd screen but, surely I would not be able to view previously taken pictures on a faulty screen. any help?. quite like this camera so would like to fix her.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Carl, that does not sound like a bad LCD at all. This sounds like an error with the CCD unit. Make sure that the CCD flex it is properly seated and that the latch on the connector is closed. The CCD itself is fairly costly and it may pay off to buy a camera with other issues and use it for parts. The parts number for the CCD is VEK0L97. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I know this is a decade old, but would you have any idea where I could find this sensor? I have the same camera with the same issue, but I can't find a new or used VEK0L97 sensor anywhere. Anything helps! :)
さんによる
@marcusvolp18949 just baes on age,the sensor will be hard to come by. I noticed that Amazon sells a lens with the CCD sensor included, but it's pricey. I'd consider trying to purchase a "bad " camera off ebay and harvest the sensor from that.
さんによる
コメントを追加
回答を追加する
Carl さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 20
今までの合計 2,584
