メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20回答 すべてを表示
It will be washing then stop,and F 1 comes up.
The washer will stop and F 1 comes up. What does this mean?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Bill, the error in general indicates that the pressure signal is out of range. The control board monitors the water level signal internally on the control board. If the control board senses something wrong, you will get this error code. If the pressure hose & air dome checks good, you will need to have the control board replaced. Here is the other issue. There was a recall on the control board for exactly that reason. The "dreaded F1" error. So you could try and contact the dealer you purchased the washer from or try to contact Kenmore itself. If that does not yield any result, You'll probably have to replace the control board yourself. The part number is W10189966 and the going rate is around $200 US for a new board. Here is a a video that shows the replacement, and the least expensive part I found is on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bill さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 295
