メインコンテンツにスキップ
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
I need to disable the PW on my laptop...
On my old desktop, via the motherboard. There's a jumper pin to disable the PW. Is there one on a Dell E6500 Latitude, and do you have a schematic of the MB and a list of the surface mount jumper designations?
Hurry...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Kevin Wilson, no there is not one. /most modern laptops no longer store the password in battery-backed RAM. those were the once you could reset by pulling the battery or a jumper setting. More modern motherboards use standard SPI flash chips to store the BIOS data. You should contact Dell and once you prove you are the rightful owner, they will help you. There may be a few ways to get it reset with your Service tag number. Check on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for the assist.
さんによる
Hello Bro's i need help
I bought few day Ago 3 dell latitude, 2 e6500 and 1 of e6400.
My problem is ...I already had media creation tool windows usb stick and I Installed e6400 , perfect, is working.
But the 2 of dell latitude e6500, if I start those same : need authentication password and ....like this, so password is important problem, but I o haven't Any bios password got from the guy, which sell this....
So one of them is under laptop service tag: 6JCJN4J
And the other one also service tag:CJ3T34J.
IF I wanna try to enter anything nothing what I click on the tastur is to see on screen why? And also my windows usb stick is not helping to boot this....
Please I thing my Turkish old turkey user brother can yüzde yüz help 🙏 😊
さんによる
コメントを追加
回答を追加する
Kevin Wilson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,140
