メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
Darkness on left side of LCD screen
I have just replaced the digitiser on an ipad 3rd generation.
The unit had been dropped and when I removed the cracked glass there were two of the zif connectors locking bars loose in the case.
I replaced the glass put everything back and turned the unit on, it works fine except there is a dark band down the left side of the screen, when i rotate the unit the dark band is evident.
Is this because the LCD zif socket locking bar is broken and how could this be repaired, if possible?
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Here's the deal-- when the lcd connector is loose, the lcd flex can easily slide out. On any I device, pulling the led flex while the led is on will cause a transient current spike that can burn the backlight filter. I this iPad there are two backlight circuits one for each side of the screen. Yours has a blown backlight filter in one line. This is a straightforward board-level repair--possibly DIY with excellent soldering skills. You should also have the lcdconnector replaced to prevent this from happening again--that is also a straightforward board level repair but not DIY.
Jessa
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
One of a few things has happened. You either need a new LCD cable, new LCD or the board has sustained some sort of damage. Look for bent or broken pins on the connectors. Other possibilities is something being shorted out. Did you use anything metal to lift the leavers?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thanks for you reply>
I only ever used plastic spudgers. On the initial look the LCD zif lock was broken and as I have not removed the logic board not sure where the second zip lock bracket would have come from, certainly not the top of the logic board. To note the second floating lock bar is the same length as the LCD zip lock bar
さんによる
Hey, I used a metal spudger to lift the zif bars on mine and now I have the right side of the screen showing dimmer than the other half. Could you tell me what can be done about this?
さんによる
See my answer below --send out for backlight filter replacement.
さんによる
My iPad also is dimmer on the right, after replacing the screen / digitizer and WiFi antenna. At first, the LCD did not come on at all. Turned out that a Hard Reset was needed to wake it up. But then the right side was dim. tried reseting the cable, no change. Ya know what? I think Ill live with it.
さんによる
コメントを追加
This is going to sound really dumb...but have you tried soft resetting the device? We had an iPad 4 that was dim on the right side, technician turned it off entirely during the repair, tried a new LCD, multitude of things, all to no effect. I tried reseating it (didn't work) then soft reset the device by holding power and home instead of shutting the thing off entirely. Booted back up, and the backlight's been fine since.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nick Turner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 10,468
