メインコンテンツにスキップ
Miniature one watt version of the classic Marshall half stack. With a tone knob and overdrive channel, it offers portability without sacrificing playability.
7回答 すべてを表示
Micro Amp Battery power not working.
My MS-2R micro amp by Marshall has never failed me in the past but I recently noticed that when I try to use battery power it doesn't work. The wall input works and sounds fine but the battery power doesn't work. I have replaced and used at least 3 different batteries but still no solution.
please help, have a nice day
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Had same problem
I Took the thing apart and there was nothing wrong, I took the wires off the battery contacts and put them directly onto the battery and it worked. So I discovered the problem was the battery wasn't wedged up against the the contacts hard enough. So I cut a piece of card and folded it in half and wedged the battery in there. Switched it on and it started first time, never had a problem since
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Ahhh thank you!! This worked for me - I also had looked inside and all wires seemed fine - did as you suggested and bingo!
さんによる
コメントを追加
回答を追加する
Jellyfish さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 28
今までの合計 3,136
