2003 Citroen C5 V6 - Is this a model with problems?
I haven't found someone that fix the automatic gearbox well in this car. Do you have instructions?
Please IFIXIT,
assist me to start (Citroen C5V6/2002/Automatic).
The Start motor is replaced with Valeo! but seems the Engine to be locked?
I scerwed upp the SPARKPLUG and LIFTED the rear wheels to be able to see the V^ engine rotation.
I have performed all modes by Automatic gear but no changes seems.
asking you how I can bring the Crank shaft to rotate with rear wheel?automatic gear should be on which position accordignly?
thanks and ready to kompensate with bank card.
best regards.
Fasa
fasason@maim.com
このアンサーは役に立ちましたか?
Problem here is language , sounds like there is no power to the wheels sounds like it could be the EMV valves in the gearbox it needs to go onto a Citroen diagnostic unit to find out what's wrong !
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 1,406
